How to fix NetworkScanner exception: System.TypeInitializationException?
ko414du4
Hello all,
I have been following the ABB tutorial PC SDK getting-started (http://developercenter.robotstudio.com/pcsdk/gettingstarted) on scanning controllers available on the network. However, NetworkScanner class keeps throwing the following exception:
My PC SDK version is 6.04. I am using Visual Studio 2015 Community Edition; .Net framework: 4.6
I can't find any reference on how to fix this issue. Help please.. Thank you.
Best Answer
If you check the innerexception then you will read that you are missing the reference/assembly "RobotStudio.Services.RobApi". After adding this reference "RobotStudio.Services.RobApi.dll" it will work.
5
Always look at the inner exceptionIn my case was due to the fact that <configSections> was not the first child of <configuration>RegardsFederico
