Creating new solution with RW 5.15 not possible in RS 6.04
I am having a problem with RobotStudio. When I try to create a new "Solution with Station and Robot Controller", I am not able to create a station using RobotWare 5.15.13 or RW 5.14, I just can't select "Create new". Creating a station with a RW 6.x or 5.60 works, but not with RW version below. According to RS Release Notes, there should be no problem.
When I try to create a new station in RobotStudio 6.03, only a few robots with cryptic names (paint robots?) can be selected with RobotWare 5.15:
What works is creating a new system in the Controller tab, and then adding that system to an empty station. I also reinstalled both RobotStudio and RobotWare, and tested it on a different PC, there is the same behaviour. Did I miss something, or is this a bug?
Regards
Matthias
Regards
Matthias
Hi Matthias,
This is by design, template systems for older RW are no longer supported. I recommend you use System From Layout instead.
Regards,
Johannes
Johannes Weiman
Software Engineer
Ok, thank you.
Regards
Matthias
- 858 RAPID Programming
