PCSDK 6.05. BACKUP-Error
I was creating an PC-SDK-Application and getting some troubles with RW 6.04.01 on
the real robot system.
I have also troubles creating a BACKUP of the system - VC is working and real system is creating errors.
The robot system is creating a BACKUP-Error - Error-ID: 11020.
My source code:
private void saveFileDialog1_FileOk(object sender, CancelEventArgs e)
if (controllerLokal != null || saveFileDialog1.FileName.ToString() != "" || saveFileDialog1.FileName != null)
try
string backupDir = saveFileDialog1.FileName.ToString();
this.controllerLokal.BackupCompleted += new EventHandler<BackupEventArgs>(Controller_BackupCompleted);
this.controllerLokal.Backup(backupDir);
catch
ShowMessage(translator.getText("Backupfehler"));
else
I would be appreciated for help
Thank you in advance
My source code:
try
catch
else
