eio.cfg in the IRC5
I have problems to define the length of a group of inputs (eio.cfg)
with the new controller IRC5.
Someone can i help me?
Wher can i get the user guide for this controller?
  • Group signsal is consist of following elements; Name, SignalType, Unit, UnitMap...
    and UnitMap defines the length of Group signal.  See the example below. The value '0-3' are the address of each IO unit where 4 digits are defined as a Group Input, giModel.  It is important that the signal address starts from zero.
    -Name "giModel" -SignalType "GI" -Unit "BOARD10" -UnitMap "0-3"
    2006-12-06_001446_EIO.zip
    For further information, Read the Tech. Reference Manual, "System Parameters"
    Good Luck!
  • Thank you very much innebandy
    Your answer me has been of great help.
    Now I have the problem to define more of a group of inputs and only me the first one works.
