Lazy drag event
One small yet annoying problem in RS is what I call a lazy drag event. When you quickly drag and drop some item in Layout or path tree the object being moved is not the one you clicked on but the one below (or above) it. Like in the example below, I want to move path HaeValmis as a routine call on main by dragging and dropping it. Instead the item being moved is the first move command in HaeValmis. I guess there is a small delay in mouse drag event so the mouse cursor has moved slightly when the item under the cursor is recognized as the dragged item. I don't know if this happens on other PCs and I can live with it when I know about it. But it's something I would like to work better in this otherwise near-perfect software. Have a nice summer everybody!
BR, Keke
