Help with GetDirecotry/CopyDirectory
Bpena
I am simply trying to copy a directory from a robot controller on the network to the local hard drive but i keep receiving this error:
System.InvalidOperationException: 'Operation is not valid due to the current state of the object.'
Here is my code:
Here is my code:
private void SycnButton_Click(object sender, EventArgs e)
string controllerid;
string localpath;
string remoteDir = aController.FileSystem.RemoteDirectory;
localpath = @C:\Users\ + Environment.UserName + @\Documents\RobotStudio\Temp\;
controllerid = aController.SystemName;
aController.FileSystem.GetDirectory(remoteDir, localpath);
Can someone please point me in the right direction, thank you in advanced!
I'm experiencing the same issue, did you have any luck in resolving this?0
