PC SDK: read and write RECORD in C#
ko414du4
Greetings all,
I have a RECORD and a variable array of that type as follows:
How can I access myRecs in C#? I tried using structure but then I am not sure how to use it or if have defined it correctly. Here is my structure:
Any help and hints are deeply appreciated.
RECORD rec
num num1;
robtarget tgt;
ENDRECORD
TASK PERS rec myRecs{3}:=[
[2,[[200,300,400],[1,1,1,1],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]],
[2,[[200,300,400],[1,1,1,1],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]]]];
public struct Rec : IRapidData
private Num num1;
private RobTarget tgt;
public Rec(Num num1, RobTarget tgt)
this.num1 = num1;
this.tgt = tgt;
public Num Num1
get
return num1;
set
num1 = value;
public RobTarget Tgt
get
return tgt;
set
tgt = value;
public void Fill(string value)
throw new NotImplementedException();
public void Fill(DataNode root)
public void FillFromString(string newValue)
public DataNode ToStructure()
}Any help and hints are deeply appreciated.
