Function WaitWObj not found
I have created in the past some Solutions using this function without any problems. But now every time I create a new solution, this function is not available.
Im using the IRB 5400 + conveyor tracking with RS 6.05 (robotware 6.05 also)
As you can see I have created the conveyor, then created the connection and added an object to it. The object was placed on the conveyor and attached..
But when I try to wait for the object, WaitWObj is not where it used to be.
Thank you in advance
That is strange, it should be added automatically if 606-1 Conveyor Tracking is available. How did you create the controller?Johannes Weiman
Software Engineer
You will need to add it under Home>Path programming>Edit instruction templates.
"Edit instruction templates" it the tab to the right of "Path Programming"
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 69 OmniCore
- 839 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
