Auto acknowledge input
Can anyone explain the Auto acknowledge input option that is find under Engineering Tool in Installation Manager.
I did check the box while I was creating a new system but I can´t find out what changes it makes to the system.
Br:Rickard
  • soup
    soup ✭✭✭
    It's an option which allows the normally manual process of acknowledging that the system was switched into Auto on the pendant to be preformed by a signal. Example of use: The signal could be used by a safety-rated PLC to acknowledge Auto mode via logic over requiring a human to push the acknowledge on the pendant.
