Behavior visible robotware 6.05.01
rob_lentz
in ScreenMaker
Hi All,
When upgrading the robotware from version 6.05.00.01 to 6.05.01, the behavior of an object is visible, not the same as before.
In the previous robotware versions, the behavior was triggered immediately, after updating the robotware, behavior is only triggered when:
1. Start screen maker application
2. Activate the visible behavior
3. Switch to another application (move, backup data edit, etc.)
4. Switch to screenmaker application.
Is there a solution here? It's scary that this is happening!
i believe I am experiencing the same problem,
If i open the application my LED indicators are accurate at that moment, yet they do not actively update.
to update the change in value I need to close the application and re-open it
i.e. my led indicators dont change with the signal they are tied to, unless i close and reopen the application
robotware 6.5.2
screenmaker 6.5.115
robotstudio 6.6.1 (32 bit)
update: it also will update the indicators if i navigate away from the application and then back to it.
Post edited by khewes19 on0 -
khewes19 said:i believe I am experiencing the same problem,
robotware 6.5.2
screenmaker 6.5.115
Solution to above:
figured mine out, i had the wrong data tagged
simple mistake that was overlooked
