Visible behaviour Objects
When upgrading the Robotware to 6.05.01 from 6.05.00.01 the visible behaviour of an object will no longer work properly.
In the previous Robotware version the visibility was activated immediatly, with the new robotware version the flexpendant screen must be changed for example:
1. HMI made with Screenmaker.
2. Activated visible behaviour
3. Switch to data editor / jogging . backup etc.
4 Switch to HMI made with screenmaker.
Visible behaviour is activated.
In the previous robotware versions the visibility was activated immediatly.
Is there a work around for this, or will there be an update.
Thx,
  • I'm currently also experience this bug but have not yet found a work around. Please let me know if you have any progress.
  • I have upgraded to RW 5.05.02, then the visibility object works for a short time (5 times), there after we have the same issues as in robotware 5.05.01.
    Any suggestions?
    Kind regards,
    Rob
