S4C + PC serial communication
i have a S4C controller with a IRB1400 M97A and i want read information from PC by RS232.
i allready instaled Advanced Functions but i can't create instruction like VAR or OPEN or etc.
Someone can help me with sequence to create simple program to read from RS232?
thanks,
Emanuel Machado
here are some examples to read data from a serial port.VAR iodev deRS232;
Open "sio1:", deRS232\Read;
stData:=ReadStr(deRS232\Time:=30);
nData:=ReadNum(deRS232\Time:=30);
Close deRS232;
You could aslo read and write binary data via the same channel:
Sending "Hello world" to the partner.
VAR iodev deRS232;
VAR num nOutBuffer{20};
VAR num nInput;
Open "sio1:", deRS232\Bin;
nOutBuffer {1} := 5; !( ENQ )
WriteBin deRS232, nOutBuffer, 1;
nInput := ReadBin (deRS232\Time:= 0.1);
IF nInput = 6 THEN !( ACK )
nOutBuffer {1} := 2; ! ( STX )
nOutBuffer {2} := 72; !( ’H’ )
nOutBuffer {3} := 101; ! ( ’e’ )
nOutBuffer {4} := 108; !( ’l’ )
nOutBuffer {5} := 108; !( ’l’ )
nOutBuffer {6} := 111; !( ’o’ )
nOutBuffer {7} := 32; !( ’ ’ )
nOutBuffer {8} := StrToByte("w"\Char); !( ’w’ )
nOutBuffer {9} := StrToByte("o"\Char); !( ’o’ )
nOutBuffer {10} := StrToByte("r"\Char); !( ’r’ )
nOutBuffer {11} := StrToByte("l"\Char); !( ’l’ )
nOutBuffer {12} := StrToByte("d"\Char); !( ’d’ )
nOutBuffer {13} := 3; ( ETX )
WriteBin deRS232, nOutBuffer, 13;
ENDIF
Close deRS232;
Besrt regards
Micky
- 40 AppStudio
