Create a new line with the command Write
I am writing in a text file with a RAPID code using commands like Write printer, " " ...
I would like to write a new line between each data I write,. To do so, I have tried "\n" like in C++ but it doesn't work.
What's the new line character in the ABB RAPID language?
Thanks a lot for your help
  • If I am understanding you right, you want a blank line to separate the lines of code.  Write  ComDevice " ";
    Lee Justice
  • Yes, It is exactly that! Thanks a lot I will try this tomorrow
