System Variable - Robot Moved In Jog
simone
Is it present a System Variable by means is possible to check if the robot has been moved in Jog, i.e. after Automatic stop.
Once the program is restarted, could I use the status of this System Variable to reset, set, assign... some variables (num,bool...) declared and used in the main program.
Regards,
Simone
Anyone has a suggestion abot this topic?0
Search the System Output named "RegainDistError" in the 3HAC17076-1 System Parameters manual.
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 34 AppStudio
