Automatically save Event Log Messages
I have a IRB1200 with IRC5 Compact controller running RobotWare 6.03
I want to be able to save the Event Log Messages log on the Teach Pendant to a text file via RAPID code.
I mean the
same way as if you press the status bar on the Teach pendant to view event
messages
and then press ‘Save all logs as…’ and save the event messages to a .txt file.
So is this possible to do in RAPID, or do I have to use the PC SDK?
Regards, Axel
