ToolData as a parameter
I'm trying to pass a tool into a parameter for example:  PROC TestProgram(PERS tooldata TempTool)  and the call would be "TestProgram (tTool);" I don't get any syntax errors but I do get a compile error saying that tTool is not a PERS but it is.
Argument error(123): Argument for 'PERS' parameter tTool is not a persistent reference or is read only.
Is it possible to pass tooldata into a PROC as a parameter?
  • ko414du4
    ko414du4
    edited October 2017
    Hi Shawndietrich,
    Yes it's possible. I had a success with this one below. The error was because the syntax of calling the routine is incorrect (use of brackets: brackets are for calling functions), such as passingToolDataTrial(myTool) instead of passingToolDataTrial myTool.
    Result is shown below as well.
