How to program an input and outputs
i need assistance on how to program inputs and outputs on to an ABB arm robot.
First, you need to define your signals in the Configuration Editor (I/O Domain), then (after a restart of the controller) you can use them from RAPID using e.g. SetDO, WaitDI. Check man RAPID instrucion manual and the system parameter manual. Both are available in RobotStudio.Henrik Berlin
ABB0
- 858 RAPID Programming
