Copy robtarget array, losing data
Using robotstudio version 6.06, using virtual TP to copy robtarget arrays of a dimension larger than 5, some data are being lost in the declaration. The copied array has the same dimensional declaration, but the number of declared robtargets in the array gets cut down to 4. I tested it with a num array, no problem.
Lee Justice
Hi everybody,
I'm not sure to speak about the same problem, but maybe.
When you copy/paste a path or an instruction in the Path&Targets tree (Hom tab), the clipboard is empty each time, it doesn't keep the last copy.
Thanks
RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110
