DefFrame in a DefDframe
Hi !
I use a DefDframe to adjuste a cutting pattern to my part.
Inside this program I need to setup a frame using DefFrame to make a particular cutout.
If I use 3 point of my program does the displacement of the frame will be applied or the DefFrame will use the raw coordinate of the point ?
I think of using 3 stored CrobT within the DefDFrame to make my DefFrame does it has more chance to work ?
Thanks !
  • My idea to go to 3 points in the DefDframe and store them to create the DefFrame seem to work.
