Electronic Position Switch Option and Cyclic Brake Check
leszekw
Dear All,
In the current stage of the project I work only offline.
The robot I use has only EPS option, without SafeMove.
In IO System tab I can see some signals for CBC, but I can't find any CBC setup wizard.
Is CBC available with EPS? Is CBC standard feature, even if SafeMove is not installed?
Best Regards
Les
