Change HomePosition of Robot-Mechanism
daniel72
if i have an robot mechanism in my staion without any rapid code inside VC, i can jump to its home-postion in RS-HOME-Tab/Layout/RightClick to Robot-Mechanism/jump-home in menue. Where is this home-position defined? Is it customizable?
Thanks
Daniel
Thanks
Daniel
If you right click and select "Modify Mechanism" there is a HomePose defined.Per Svensson
Consat Engineering0
- 88 OmniCore
- 42 AppStudio
