Change name of target
Hello I have a small problem.
When creating path in robotstudio , it automatically sets their name to me as to change the names of targets and paths all at once.
Instead of the target name to be arbitrary
thanks in advance for answers
Regards,
Dawid (POLAND)
  • You can either rename it in "Path and Targets" and synchronise it to Rapid. Or you can manually edit the names in Rapid Editor and synchronise the code to station. Make sure to apply the changes in Rapid editor when you change the code.
