Parts reappear when using clip plane
I've started to use clip plane a lot lately and I find it very useful. Two thoughts/suggestions though:
- Maybe make it more obvious that the freehand tools are used for clip plane. First I only used the coordinates to move the plane but could never got my head around it. It was a coincident I found the freehand tools.
- Why does parts that are covered by clip plane reappear when mouse pointer hover over it? I noticed it can be fixed by not having any selection active, but for example when you need to navigate robot in a tight machine and use clip plane to get a clear view of the robot, then you have to use "part selection" to select the robot to jog. And every time you try to jog the robot the machine reappears and cover the robot. Gah!
/David
