Bosch 6100 timer
Hii ALL;I have yrc5-6600 spotwelding robot and this robot control weld via analog bosch timer which verison is 6100.6300L. This robot working without problem.
But i can not control air from propotion valf with manual mode with I/O. This valf connected to the timer and timer program changed valf output value when change program number (Spot number), So I want to change this valf value from flex pendant(FP) with use I/O when the robot is manual mode . Could you help me?
hi, as i know we can control the air valve value in the flex pendant with use i/o when the robot is in manual mode. but we don't need to set the analog signal, we can just set the signal of program number, and hold the FP , push the enable swith, then we set the signal of weld start. thus the valve value will be set according to the program in the timer.
