PdispOn
Klaus
Is it possible to use the Pdisp On/Off when you use wobj with robhold true.
I can't get it to work.
the routine just run as programmed
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Found out the problem my self.
The problem was that i used a SearchL with a Trap routine.
You can't first connect a trap routine and then use a SearchL. The SearchL use all CPU soo the trap routine doesen't start.
Please put it in the manual soo others don't use a lot of time to find this out
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
