Source does not maintain physics properties
Whenever I copy an object using a Source SmartCompoent, I loose the Physics behaviour/properties of the copied object. The expected behaviour should be to maintain all the object properties, or have an option to keep them or loose them.
Using the PhysicsControl SmartComponent is not an option, since we need on for each object, which does not make sense (in my project I have several objects created on the fly which move from queue to queue).
