Connect Robotstudio to PLC
Hi. I was wondering that is it possible to connect PLC to RobotStudio and read real IO signals to the station in RobotStudio? What this kind of setup would require?
  • DenisFR
    DenisFR ✭✭✭
    What is your type of PLC?
    If it is a SIEMENS one, you can use RSConnectDIOToSnap7 or RSConnectGIOToSnap7 in Add-ins.
  • Thank you for your answer. We have been using mainly Beckhoff devices, for example CX51x0 Embedded PC.
  • DenisFR
    DenisFR ✭✭✭
    Which protocol do you use?
  • We have been using mainly profinet. Robot as a device/slave.
  • DenisFR
    DenisFR ✭✭✭
    So these SmartComponents should works.
