Undefined units on 3D-file
I'm trying to import a jt file of a robot gripper. Problemet er at de dele bliver meget små når de importeres. At first it was seen that the import was unsuccessful but the file was in the Layout tab. When I right click and click examine I could see the part but it was very small.
Þegar ég opended the same jt file in NX I first got a warning that the units are undefined but the model should be up as it should. When I measured between 2 points in NX it showed 500mm, those same points in Robotstudio showed 0.5mm. So my guess is tht Robotstudio takes a wrong guess at the undefined units and interprets m as mm. Is there a way to tell Robotstudio how to interpret the undefined units or is it possible to scale up the model x1000?
I tried to change the units under options from mm to m but get the same result.
/Johan
