RS 6.07 new I/O-Configurator
First of all many thanks and great praise for your own I/O-configurator. Finally, not having to work with the awful KW-Software is a pleasure.
First impression of your concept is very good! Two things your developers should look at:
1.
If you accidentally close the windows "Properties" or "Device Catalog" in
the I / O Configurator by clicking the cross symbol in that windows, both windows disappear and
never come back. Repair of RS does not
help. Also uninstalling and reinstalling RS does not help (because the registy does not seem to be cleaned up properly). I had to install RS on a clean windows-image-to solve this problem!2.
If a group signal is defined in the signal editor and you first write
the mapping 16-32 and the signal type still is "di" or "do" shows the mapping is red, if you now change "di" on "gi" mapping remains red, you must first delete mapping entry
and rewrite again to become red off
Daniel
To Point 1 i have found the solution:
