Buuls eye
Klaus
Is it possible to test the bulls eye option in rs. 5.07. I can select the option while config the VC but can i then test the way i works. I Whant too use it on other tools then Weld guns
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
You would need to simulate (in the I/O) the tool breaking the beam. So it would not be a very good test of what would happen in the real world.
- 304 PowerPacs
- 2.8K Robot Controller
- 355 IRC5
- 74 OmniCore
- 850 RAPID Programming
- 26 AppStudio
