anybus gateway configuration
hello to all.
i wants to add Anybus gateway Profinet I/O Slave to DeviceNet scanner Master in IRC5 so that IRC5 is being controlled by Siemens plc s7-1215. The unit type details i defined in irc5 is attached herewith. Also i defined a new Unit connected to the Unit Type. DeviceNet master address is 2. For the new unit the devicenet default address set is 63.
but there is problem in communiction. Gateway NS light is flickering which means it is on but no network is established with slave devicenet (IRC5).
any help please where the problem is.
  • by Default DN-SLave available in EIO.Cfg doesn't contains info about gateway so how it can be used fr the gateway. DN_Slave details are attached also.
