Check if motion task is running in RAPID?
Is there a RAPID command I can use within a non-motion task to see if a Motion task is currently running?
Best Answer
  • DenisFR
    DenisFR ✭✭✭
    You can use
    IF RunMode(\Main)=RUN_CONT_CYCLE THEN
  • TaskExecuting is the ticket! Thank you lemster68!
