a question on error-handling in API
for a target freshly created, the attempt to read the target's robotconfiguration property arises an "No configuration" error, and goes to my error-handling code. Is there any way to detect this so that it won't go to the errorr-handling code? I tried IsEmpty, and a few other Is.. functions in vB in vain.
Thank you very much.
John
  • Hi
    What you could do is something like this
    On Error Resume Next
    Dim t as Target
    Set t = ActiveStation.Targets("your target")
    if t.RobotConfiguration.Cf1 = null then
      ' Do the error handling
    End If
    Per Svensson
    Consat Engineering
  • Hi, thank you very much for your reply.
    I may not make myself understood. My code would be like this:
    On Error Goto HandleError
    If t.RobotConfiguration.cf1 = null Then
    ... do stuff ...
    Else
    ... do other stuff ...
    End If
    HandleError:
    ... Error handling code ...
    When executing the "If t.RobotConfiguration.cf1 = null Then", it immediately goes to the error handling routine below. I have also tried " if IsNull(t.RobotConfiguration) then ", and the same thing happened.
    It looks like any reference to t.RobotConfiguration in any fashion leads to an error, while I am trying to find a API or VB function to acheive the logic structure similar to the above code.
  • Hi
    The difference is that instead of jumping to the error handler you define that if there is an error you continue with the next instruction
    instead of
    You can also turn off or change how the error handler should behave during program execution.
    Per Svensson
    Consat Engineering
  • Got it. Thank you very much.
