Get the parent controller of a signal
scottMHA
I have an event handler (see below) that is raised when a signal's value changes.
<div>private void Signal_Changed(object sender, SignalChangedEventArgs e)</div><div> {</div><div> Signal signal = sender as Signal;</div><div> }</div>From the signal object (Signal signal) is there any way to get what controller/system that signals originated from? All im after is the name of the controller/system.0
