Teach Pendant Hard reset.
Hello everyone,
Is there any way to do a hard reset to a teach pendant?
For example, a screen will stop functioning and instead of replacing it. Could i just press a combination of buttons to reset it?
Best Answer
  • Shell
    Shell
    Answer ✓
    There is a little hole on the back side of the flexpendant. If you press it with the flexpendant pointer for example, the screen will be restarted.
    That is for the new flexpendants, the old ones have a joystick combination to restart them.
  • Also if the screen that fails to load is a Screenmaker screen you will have the .dll files on the home directory of the robot, make a backup, delete that files and restart the flexpendant as described on the previous post. Take in mind that doing this will erase that screen completely and this only works with the custom screens from screenmaker, screens like the arcware or spotware cannot be deleted.
  • Do you know what the joystick combination for the old flexpendants are?
  • soup
    soup ✭✭✭
    It's been a while, but I think it's: right, right, right, left, down
