Program Modules suddenly deleted
MDFB
Hi everyone,
I was changing some robtargets definition in RobotStudio and after applying the changes, on the FlexPendant I had a message about a problem with the programs,
there wasn't any module to run. I checked on Robotstudio and both,T_PLC and T_ROB1 and all the modules in them, were erased. I have no idea how could this happened,
I would appreciate if you help me to find out what the problem could have been. It's so easy to erase this kind of important stuff?
Thanks!
In order to troubleshoot this issue you could use the RobotStudio Support Tool (a program which comes with RS installation, search for it via Start Menu).
Look in the tab Fault Log Files and analyze the logs there.
There is a way of recovering the modules, if this would happen again. Autosave is enabled by default in RS and the contents can be found in this location: %LOCALAPPDATA%\Temp\RobotStudio\AutoSave\
I hope this helps.
—Maxim RiabichevPC Software Support Engineer1
- 38 AppStudio
