Which Assembly file has to be added as a reference for designing an User Interface via C#?
I want to design an User Interface to communicate with Robotstudio. But I could not add the controls. Which dll should be referenced ?
If you want a UI towards the virtual controller, you can use the PCSDK and the DLL's included in the package.
http://developercenter.robotstudio.com/pcsdk
If you want a UI towards RobotStudio, you can use the RobotStudio SDK and the DLL's included in the package.
http://developercenter.robotstudio.com/robotstudio
Consult the manuals for the DLL's.
Can you please explain how PCSDK is used to create an application towards the virtual controller ? Is it the RAPID Editor that you are referring to ?0
