Pick and Place Programm
abdou22
Hello everyone,
in my project, a component should be picked up and moved to another location with a YuMi robot.
First, YuMi should photograph the component so that he can identify it in the pick-and-place program and then record it (the camera is on the left arm of the robot - on a moving part of the robot).I did the image processing, but I have no idea what the program looks like and what to do now.
What about the camera position, where should I save it?
In short: The left arm should photograph the component and the right arm should pick it up and move it to another position.
thank you very much in advance
Hi @abdou22.
Probably you already reach your aim, otherwise I can suggest you to use the example in the code snippet of the integrated vision (move to detected object)
It will be someting like that:- Build up your job and do the calibration.
- Move the left arm in the photo position.
- After that, execute the rapid program (like in the snippet), in the task of the right arm.
- Move away the left arm.
- Pick your object with the right arm.
