RS 6.07.01: Error when adding option to VC
Hi!
Have a VC where i try to ad PC Interface to the controller, and i get this error:
It is possible to add PC Interface to a VC with RobotWare 6.07.01 but not to earlier.
  • Maxim Riabichev
    edited August 2018
    Hello Erik,
    Just to confirm, you're using RobotStudio 6.07.01 and RobotWare 6.07.00 (or below) to get this error?
    You get no error with RS 6.07.01 and RW 6.07.01?
    Maxim Riabichev
    PC Software Support Engineer
  • Hi!
    I run RS 6.07.01 but i have tried some more and it seams it doesn't matter which RW i use in the VC. This output is set when i use "Change Options" under the "Controller" tab. I can add PC interface option when I create a new system from scratch without a back up or anything.
    /Erik
