How to resolve the error in try catch block ?
Hello,You have to catch InvalidOperationException:
<div>...<br></div><div>catch (InvalidOperationException e)</div><div>{</div><div> // Do what you want</div><div>}<br></div><div>catch</div><div>{</div><div>...</div>☑️2024 - RobotStudio® User Group0 -
Hello Denis,Thank you for your answer. Now I can build the code. But I could not see any robot created in Robotstudio. I used Robotstudio Addin Template and to create the robot. Is it correct ? If not, what is the solution ? How the robot model should be created and viewed ?Thanks in advance0
Hello,RobotStudio AddIn is not to create new robot. Only to add some new features to RS.You don't need to develop AddIn to add robot. It's on the main RS.You can have a look to this video:Or search for RobotStudio tutorials.
