Assembling imported STEP files using RobotStudio Add-in
Hi everyone,
Is there is any possibilities to create Add-in, which helps to assemble the imported STEP files in RobotStudio environment.
1. I select a point on a face of Part 1.
2. Then, I transform part 2 to the point on part 1.
3. After transforming the part2, I see the part 2 origin and the selected point of part 1 is same.
I need guidance on: check the faces of 2 parts, then transform and orientate the part2 based on face of part1, (assembling operation like SOLIDWORKS )
Thanks in advance.
Thanks in advance.
