Suggestion: Tech Mode Max Orientation Speed
I don't know if this is the correct forum section for this suggestion, so admin, please move thread to right place if i'm in the wrong one.
I have a suggestion, to add a the possibility to set max orientation speed in Motion Planer when the robot is in manual mode. This so you can run the robot in 100% in manual without the SafeMove system tripping if you have speed supervision points far away from flange due to big tool or big load.
