AssemblyResolve error while debugging
Hello Everyone,
I am using RobotStudio 6.07 and trying to debug an Add-In as in http://developercenter.robotstudio.com/blobproxy/devcenter/RobotStudio/html/cf224169-9f07-47e1-b5fb-62b619c934e1.htm
I encounter a problem when I launch RobotStudio through Visual Studio. When I load the application i see the error "AssemblyResolve - Faile to load assembly..."
The problem is not there if I launch RobotStudio and only after i attach the Visual Studio debugger, and the Add-In is correctly loaded.
Does anyone knows what i am doing wrong?
Thanks
Federico
