ABB IRC5 Communication with Fronius through Anybus M40
I am currently working with a IRC5 connected to a Fronius TPSi through the Anybus M40 module supplied by Fronius.
The Fronius module keeps saying that it is not connected on the IRC5 Teach pendant. I assume that I have the wrong configuration file loaded.
Can someone please assist me with the connection settings.
Kind Regards
Morne
Kind Regards
Morne
Just to add the correct information, the robot controller is a IRB 2600, Welding power pack is a TPSi400 and the Anybus module code is ABCC-M40-PIR V.1.33
Kind Regards
Morne0 -
What communication protocol is this (EthernetIP, DeviceNet, Profinet)?
Profinet Protocol0
So far we have been using the above software to create a IPPNIO.xml file to load onto the robot, but with no progress.0 -
Sorry I will not be much help have only done one system with Profinet.
Just to cover the basics you need the controller/device option on the IRC5 - do you have this?
Do you have a copy of the ABB application manual for the Profinet option?
We have currently connect to the Profinet network through a Phoenix contact FL Switch SFN 5TX. Through this we have communications to the PLC, and to the Anybus module, but not to the Fronius TPS4000
- 304 PowerPacs
- 2.8K Robot Controller
- 354 IRC5
- 74 OmniCore
- 850 RAPID Programming
- 26 AppStudio
