INSERT PHOTO IN ROBOTSTUDIO
Could I insert photo in robotstudio simulation? if yes How?
Thanks
Thanks
Yes, you can apply images to geometry (texture) and markups:
Johannes Weiman
Software Engineer
RobotStudio Team, ABB Robotics1 -
Thank you so much for your answer, could you tell me how could I insert the image and in which format the image should be ?0
Thank you, now I can insert it, I will test it and get back to you because the image is always huge when I use markeup0
it is great, Thank you again, it is working with texture0
- 361 IRC5
- 78 OmniCore
- 853 RAPID Programming
- 30 AppStudio
