My IRB1200 joint 6 is only returning Z coordinates between 180 and -180
jseward
Hey there,
I am writing some front end UI tools for our ABB robot and while trying to execute a path that ends in rotating joint 6 360 degrees I was noticing some weird errors at execution. Turns out that the joint 6 readying I am getting back in the jogging window on the pendant shows 0 to 180 and then if I continue rotating it immediately starts at -180 and goes back to 0. Can someone explain to me where I might be able to find how to change this coordinate frame? I am seeing this with tool0.
Kind Regards,
Jon
Kind Regards,
Jon
Is your position format in Euler angles? That is what it sounds like to me. Change to joint jog to see the actual joint angles.Lee Justice0
yes the position format is in Euler angles. I was trying to accomplish the movement using a moveJ on a robtarget but since then have had more luck using MoveAbsJ on a joint target. Would this make more sense to you?0
Yes, CJointT(), then add or subtract 360, but be cautious of the joint limits.Lee Justice0
