ProgramPositionEventArgs problem in PC SDK.
YeonkyuJeong
edited October 2018 in Developer Tools
Hello eveybody!
I have ProgramPositionEventArgs Problem.
My development environment is,
OS : Windows 10
Develop Tool : Visual Studio 2015
ABBRobot : IRB 120
SDK version : RobotStudio 6.07
My code is,
public event ChangePosition_Delegate CP_Delegate = null;
private event EventHandler<ProgramPositionEventArgs> progpos_events;
this.scanner = new NetworkScanner();
this.scanner.Scan();
progpos_events = new EventHandler<ProgramPositionEventArgs>(this.PositionChangeEvent);
ControllerInfoCollection controllers = scanner.Controllers;
tRob = controller.Rapid.GetTask("T_ROB1");
tRob.ProgramPointerChanged += progpos_events;
public void PositionChangeEvent(object sender, ProgramPositionEventArgs _position)
            CP_Delegate(_position.Time.Millisecond.ToString());
then,
What is the program problem,
ProgramPosition event continue to occur...
ABB Robot move not! but, don't stop event.
Help me. please!
  • Micky
    Micky ✭✭✭
    maybe you have to use the Invoke method, like as follows:
                    if (this.InvokeRequired)
                        this.Invoke(new ProgramPositionEventHandler(PositionChangeEvent), sender, _position);
                        return;
    Best regards
    Micky
  • DeepakP
    DeepakP
    edited October 2018
    It's not clear what issue you are facing. If you just want to process time/position whenever the program pointer changes, below would be a cleaner approach-
    public delegate void ChangePosition_Delegate(string input);
    public class MonitorProgramPosition
        private Controller _robot;
        private ChangePosition_Delegate CP_Delegate = delegate (string input) { Console.WriteLine(input); };  // Just print input to console for testing
        // Event handler
        public void PositionChangeEvent(object sender, ProgramPositionEventArgs e)
            CP_Delegate(e.Time.Millisecond.ToString());
        // Connect to controller and subscribe to event
        public MonitorProgramPosition(Guid robotGUID)
            _robot = new Controller(robotGUID);
            _robot.Rapid.GetTask("T_ROB1").ProgramPointerChanged += PositionChangeEvent;
        // Just keeps program open till any button is pressed
        public void Wait()
            Console.ReadLine();
            _robot.Rapid.GetTask("T_ROB1").ProgramPointerChanged -= PositionChangeEvent;
            _robot.Logoff();
            _robot.Dispose();
    class Program
        static void Main(string[] args)
            var ppMonitor = new MonitorProgramPosition(Guid.Parse(<YourRobotGUID>));
            ppMonitor.Wait();
    }<br>
  • Thank you! Micky, DeepakP. I will try!
