UDP socket communication with virtual irc5
voidnoise
voidnoise
edited October 2018 in RAPID Programming
Hi, I am trying to send udp between virtual IRC5 and external python script but hitting problems. I am having trouble getting udp sockets to connect and communicate in to or out of robot studio. Firstly I am not that familiar with windows or robot studio which may not be helping. Initially I couldn't ping the robot studio machine from my unix machine. I played with the firewall to allow pinging and udp on all ports and the ping server responded. Next I checked that I could send udp between the windows PC and unix using python scripts. This works.
I have robot studio set up with an IRB1200 and IRC5 virtual controller with PC interface enabled. Using the following rapid code as a client send example;
MODULE socket_server
    VAR socketdev serverSocket;
    VAR socketdev clientSocket;
    VAR string data;
    PROC main()
        SocketCreate clientSocket;
        SocketConnect clientSocket, "10.0.1.29", 2021;
        SocketSend clientSocket \Str:="Hello server";
ENDMODULE
Or as a server receive example;
    VAR string data;
    PROC main()
        SocketCreate serverSocket;
        SocketBind serverSocket, "10.0.1.29", 2020;
        SocketListen serverSocket;
        SocketAccept serverSocket, clientSocket,\Time:=WAIT_MAX;
        ERROR
        IF ERRNO=ERR_SOCK_TIMEOUT THEN
            RETRY;
        ELSEIF ERRNO=ERR_SOCK_CLOSED THEN
            SocketClose clientSocket;
        SocketClose serverSocket;
        SocketBind serverSocket, "127.0.0.1", 5004;
        SocketAccept serverSocket,clientSocket,\Time:=WAIT_MAX;
        RETRY;
        ELSE
            stop;
        ENDIF
ENDMODULE
The error I get when I try to connect the client on the virtual controller and send udp out:
***  SocketConnect clientSocket, "10.0.1.29", 2021;
41574: Socket error
Description
Task: T_ROB1.
The socket must be created before it can be used in any socket instruction.
Program ref: /socket_server/main/SocketConnect/11.
Causes
The reason for this error is one of the following:
1) Socket not created at all.
2) PP movements has been done.
3) Start of program after power fail.
4) The socket has been closed after SocketCreate.
Actions
Insert a SocketCreate instruction at a suitable place in the program before the socket is used.
Recovery: ERR_SOCK_CLOSED.
When I create the server on the virtual controller it just hangs on SocketAccept serverSocket, clientSocket,\Time:=WAIT_MAX; until it times out.
Is there anything obvious I have missed out on the set up? Is windows firewall getting in the way? Im totally stumped after a day of trying to get this to work. Any advice would be greatly appreciated.
Post edited by voidnoise on
  • The server code I pasted is actually missing the socket receive line:
        VAR string data;
        PROC main()
            SocketReceive serverSocket \Str:=data;
            SocketSend clientSocket \Str:="received";
            ERROR
                RETRY;
            RETRY;
            ELSE
                stop;
            ENDIF
    ENDMODULE
