ABB IRB 6400 M97 S4C - SCSI Port: Can I connect a hard drive?
Popex
Hi, I am programming an IRB 6400 M 97 S4C with a CAD / CAM pair to mill. I have the disadvantage that the size of the files is too large to accommodate in a 1.44mb memory. We have already split the program, and generated the so-called automatic programs.
We have discovered that the DSQC 330 motherboard has a SCSI port. Does anyone know if you can connect a SCSI hard drive? what type of partition and format should the disk have?
Thank you.
Thank you.
