how to bypass one instrcution in program!
How to temprary bypass one line in robot program by using teachpandent?
For example:
MoveJ P1,Vmax,fine,tool1;
MoveJ P2,Vmax,fine,tool1;
I need temprary jump first line and run second line,when i need i can put  line 1 back to program so i don't want lose P1 point.
I trid to put "!" on front of the line change the line to comment,but I couldn't.
If anyone know how to do it pls let me know<
Thanks a lot!!!!!
  • Hi
    Why don't you just use a IF instruction like bellow
    where you control if P1 should be executed with a bool bJumpFirstLine
    IF bJumpFirstLine THEN
    ELSE
    ENDIF
    Per Svensson
    Consat Engineering
  • Hi Jefftoron
    Even easier is
     IF FALSE MoveJ P1, vmax, fine, tool1;
    Then you just need to change FALSE into TRUE to re-enable the line.
    Bye
    Claudio
  • thx a lot!
